International 350 tractor Utility Steering box rebuilding
Posted by Bowwie on July 30, 2012 at 16:19:33 from (96.63.33.168):
third party image
My 350 has the 364453R95 Gear,Steering,Assembly installed. see attachment. Power Steering - I am having a dilly of a time finding any info on the following replacement parts. Here are the International part numbers:
2 of 368371R1- Race, inner, thrust bearing
2 of 368373R1- Race, outer, thrust bearing ( subs to A13067 )
1 of 368076R1- Washer, tongued
1 of 366160R1- Washer, lock
1 of 365954R91- Bearing, roller, w/race 366145R1 nineteen rollers and two springs
1 of 364627R1- Washer, thrust, gear shaft end
2 of 366158R1- Ring, piston
2 of 366137R1- Bushing, housing cam bore
I believe some part numbers supersede.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
