Re: ih 656 amp light help
Posted by Janicholson on August 12, 2012 at 06:57:59 from (96.24.99.126):
In Reply to: ih 656 amp light help posted by mh mo. on August 12, 2012 at 06:41:06:
If your alternator is the original, it has an external Voltage regulator. It is possible with age, that it is showing some current through the light when running. It happens. There should be voltage on both leads to the light, resulting in no light when running. when stopped with the key on, the light gets grounded in the regulator, and has current will flow from the key through the light, to the VR.
If the charging voltage is close to 14.2, I would leave it as is. If it is less than 13.8 I would probably have the alt and VR checked. Most likely the VR. Jim
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
