The tractor more than likely has a Belly pump that could be used for the Hog. The bars should be used for pulling all implements that are not 3 point. THe belly pump is in the belly of the tractor, and has fittings on both sides. ignore the left side rear fitting as it is a delayed action port. The other two are connected internally, and both are one way hydraulics like the pump now mounted to the engine. The clutch must be out for the belly pump to work. it takes 6 quarts to fill (right side under tank, looks like a big knob) Hytran, or 20 wt non detergent engine oil will work, or what ever is in the tractor now used on the hog to prevent crossing fluids. The rod on the right of the light bar is for the pump. Pull out is lift, push in to the detent on the rod, hold, lift and push farther, lower. Jim
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
