Posted by jt on September 06, 2012 at 07:51:31 from (66.87.75.89):
In Reply to: Re: H belly pump posted by alderman on September 06, 2012 at 05:17:01:
If the H has a three point, as you.stated, it is more than likely hydraulically operated. If it is, followthe hydraulic hose to where it hooks to tractor. That should be one of the ports of the belly pump, unless someone has put a live pump behind the mag to run three point hydraulics.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
