Posted by rustred on September 10, 2012 at 19:44:36 from (72.172.100.113):
In Reply to: H points and condenser posted by j hakenwerth on September 10, 2012 at 16:41:19:
why not go through the complete tune up. check compression , adjust valves, read plugs regap or replace,points and condenser done,check dist block for wear.check plug wires.set timing. check and clean fuel filter and bowl.check carb adjustment or clean as nessesary. a few more things to do.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
