Re: New water pump and belt
Posted by rustyfarmall on September 15, 2012 at 14:18:56 from (67.55.162.174):
In Reply to: New water pump and belt posted by Jerry/MT on September 15, 2012 at 14:02:59:
Uh, no. Not on the Farmalls. The pulley on the water pump is made in two halves, and the belt is tightened or loosened by moving those 2 halves closer together (tighten) or further apart (loosen).
Likewise the generator pulley is made the same way.
Find the set screw on the pulley. It will probably have a lock nut on it. Loosen the nut, and then back the set screw out. The outer half of that pulley is on threads, just screw the pulley either in, or out, to achieve the proper tension, tighten the set screw, making sure it is IN a groove, tighten down the lock nut and you're good to go.
The owners manual has pictures. :lol: :lol:
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
