Posted by rustyfarmall on September 20, 2012 at 05:56:04 from (67.55.162.174):
In Reply to: Bead blasting carb? posted by IAtractorKid on September 19, 2012 at 18:06:57:
Go for it. Bead blasting is the only way to remove the rust and other deposits down in the bottom of the bowl. I will caution you to either remove the idle metering jet, or cover it so the sand can't get in it because it is the only part of the entire carb that is small enough for the sand to become hopelessly lodged in.
Be sure to completely blow it all out with compressed air, and then be very generous with aerosol carb cleaner into ALL of the passages, then use compressed air again.
The carb cleaner that you soak a carb in just ain't even close to what it used to be, and it won't get the job done.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
