First two, I have never seen or heard of before. Might not be appropriate for your tractor.
O-D-B should line up with the pointer on the light switch, and the letters should be upright and readable. The ones I've seen generally start about 9-10 o'clock, and run clockwise from there.
Gear shift pattern on the gas tank, centered in a location where you can read it from the seat.
"Late H, M-V12118" is not a decal. It's the identification tag for the decal set. Just because it's there doesn't mean you have to use it.
"Hitch only to drawbar" goes on the back somewhere. I've seen it on the PTO shield, or stuck on the rear end casting above the PTO.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
