I have an MD with the after market Lambert brakes. When I rebuilt them, around 10 years ago, you could get parts from IH. Probably no more. And 10 years ago the part were costly. I took my disks to the local clutch brake rebuild shop and they relined the disks for me at about 1/4 the cost of new disks from IH. If you want to keep these brakes on your tractor(they are a bit unusual), I think you could have a machine shop resurface the actuator parts that contact the disks if that is needed. I just sanded mine off. The only other parts likely to be of consequence are the balls and springs and you can likely find replacements for those that will work. If the grooves the balls run in are rough or corroded, that could be a problem. After I put the relined disks in mine and cleaned everything up, they are still working fine 10 years later.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
