Re: 400 Wiring
Posted by Janicholson on October 12, 2012 at 17:14:21 from (96.24.99.126):
In Reply to: 400 Wiring posted by MarkinMo2 on October 12, 2012 at 16:55:34:
The most likely source of "keeps on Running" is an alternator set up with the #1 terminal hooked to the ignition directly. That wire must have one of the following three things spliced into it. A light bulb from a side marker lamp (not LED), or a 3 amp diode with the marked end (band) toward the alt, or a 10 ohm 5 watt resistor. These components allow exciting current to initialize the alternator, but will not feed back into the ignition.
If no alternator, the wiring of the ballast resistor bypass on the starter relay could be wrong. The I terminal is near the big terminal hooked to the starter strap. the S terminal is near the battery cable terminal. If backwards it might continue to run. Jim
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
