Re: part no's
Posted by D Slater on October 13, 2012 at 06:33:44 from (184.15.8.46):
In Reply to: part no's posted by 34gpa on October 13, 2012 at 04:14:23:
Part numbers can be looked up but if you realy want original part numbers some won't be found.
Some part numbers were changed as time went on.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
