Re: farmall C engine surging
Posted by pete 23 on October 13, 2012 at 12:29:04 from (74.32.238.2):
In Reply to: farmall C engine surging posted by Kyle Kraft on October 13, 2012 at 05:28:48:
Also, on that surge adjustment, take the screw out and look at the spring as they are very often broken. Tons of carburetors running around with more play in that hole than you have but make sure it is not binding.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
