Re: No gas to the carb
Posted by Janicholson on October 13, 2012 at 16:44:03 from (96.24.99.126):
In Reply to: No gas to the carb posted by BigTone on October 13, 2012 at 14:44:10:
With the bowl off, put a pan under the carb and turn on the fuel. If nothing comes out, wiggle the float. it should allow fuel. If fuel does come out, lift the float gently to see if it shuts off when raised to the correct height. It is more difficult to measure the float when mounted because raising it carefully to the shut off point doesn't use gravity, it uses your sensitivity holding it up. Jim.
Today's Featured Article - Tractor Profile: Allis-Chalmers Model G - by Staff. The first Allis-Chalmers Model G was produced in 1948 in Gasden, Alabama, and was designed for vegetable gardeners, small farms and landscape businesses. It is a small compact tractor that came with a complete line of implements especially tailored for its unique design. It featured a rear-mounted Continental N62 four-cylinder engine with a 2-3/8 x 3-1/2 inch bore and stroke. The rear-mounted engine provided traction for the rear wheels while at the same time gave the tractor operator a gre ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
