Posted by dstates on October 21, 2012 at 18:09:37 from (173.18.213.205):
I've had my grandpa's '52 H now since Memorial Day. I've taken it on a dozen or so short drives and noticed it lugged down on the hills quite a bit, but just assumed it was either normal or I needed to do some tuning.
Well... I just got done with some recent changes and thought I should run it around and make sure I stopped the leaks I thought I did and see how it ran. I changed transmission oil, replaced a couple felt seals and installed a new manifold. It seemed like a brand new machine!!! It had tons of power up the hills, was louder at full throttle and seemed to be going faster in 5th than it ever has.
I think I figured out why. It was really puzzling at first. I was thinking "did the new manifold make a difference?". Why would that change anything??? However, the more I thought about it I figured it out. When I had the manifold off I was able to get behind the governor where the governor input arm is. I knew it still had a lot of dirt and crud packed in there and I worked for quite a while to clean that out since I could get to it easier. I must have gotten rid of enough crud that the input arm has full travel again. I'm just amazed. That was a fun discovery today :)
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
