A compression check is done with a screw in compression gauge. If you don't have mechanics tools, you will. A good compression tester from a real tool company will be in the area of 35$ to 100+ bucks, Craftsman for 58 is pretty good. The engine has all plugs removed. The coil is disconnected (the distributor side of the coil is a good place to disconnect) The Throttle is open wide Fuel shut off is off Fully charges good battery to spin it fast. Put the tester in #1 cylinder (front) Crank the engine for 5 compression strokes (you can hear it easily) Look at the gauge and record the data on a tablet. Do the same for each cylinder. Use a squirt oil can and put three squirts of engine oil in each spark plug hole, spin the engine with the starter to spread the oil Repeat the test now. Report back to us for diagnosis. Generally the compression should be (IIRC) 140 to 160 PSI If uniform, (within 10 % of each other) that is also good. Jim
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
