Posted by Janicholson on December 16, 2012 at 08:12:08 from (67.72.98.45):
In Reply to: 806 question posted by arky 43 on December 15, 2012 at 18:02:38:
If it is in your hand, and or available to measure, it is easy. Place the rocker on a sheet of paper and mark a circle inside the shaft hole with a sharp pencil. Without moving it, look at the center of the wear at the tip where it touches the valve stem, and make a mark on the paper at that length. Now make a mark on the paper at the center of the pushrod pocket. Using a caliper (or if none available use a 64th inch marked ruler and change to decimal inches) measure the circle diameter and divide by two to find the radius. Measure from the circle edge to each mark, and write that down. Add the circle radius found above to each. These numbers should be written as a ratio. Like 1.215:1.76 This needs to be stated so the left side is pushrod to center and valve tip to center is on the right. Divide the number one (1) by the left number, and use that result to times the right number. 1/1.215*1.76=1.449 The ratio is 1:1.449. I hope this helps some. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
