Re: Replacing oil seal on Farmall C axel ?
Posted by wayne in mn on December 21, 2012 at 08:37:16 from (64.118.12.213):
In Reply to: Replacing oil seal on Farmall C axel ? posted by Paul Shuler on December 21, 2012 at 06:13:34:
You need to remove the bull gear to get the housing & axle off as a unit. The inner bearing is held in the housing with a retaining ring and the axle cannot be removed unless the retainer is removed first.
Much easier to take the bull gear cap screw & washer out if the transmission cover is taken off first.
A seemingly simple task gets much more involved when you "dig deeper" into the problem.
Good luck.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
