Well the engine is sleeved. (dry sleeves) if you remove the existing sleeves thinner sleeves can be installed. It will not quite get to the SH dimension, but with higher compression domed pistons it will be more powerful than a stock SH. All other efforts will require boring out the cylinder block to larger diameters for bigger sleeves, or running with no sleeves. Putting a 350 engine block in it and using thinnest sleeves in that with high compression pistons (and its cam carb intake and distributor is about as powerful as you can get without compromising farm use or getting carried away with making a puller only. Jim
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
