Posted by Bob M on January 12, 2013 at 12:12:34 from (67.240.174.32):
In Reply to: 450 questions posted by mike Fitz on January 12, 2013 at 11:40:47:
Before you tear into the governor, first check the the linkage is properly synchronized (adjusted) to the carb throttle shaft:
Remove the cover from the governor riser (the sloped cover with a vent tube heading up to the head). Remove the cotter pin then the pivot pin from the bellcrank inside the riser. Set the governor hand lever to max speed, then pull up on both the adjusting block and the throttle shaft bellcrank as far as they will go. Now while holding the parts up, try to reinsert the pivot pin - it should slide in easily.
If it does not, loosen the locknut and turn the adjusting block up or down on the threads until the pin slides in easily. The governor will now be synchronized with the carburetor.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
