I dont have the specs on your genny, Bob M or Jim might?? However, Id guess 20 amps is all it may pump on a good day AT HIGH RPM
Try to dead ground the Gennys FLD post and see what happens??? If charging dont increaSE much the VR is NOT the problem nor will adjustments help. If it does increase, (may need adjusted up) insure the VR has a good ground (try a jumper to grnd)
If its a 3 brush genny, adjusting the third brush may help....Insure belt is tight........Can you use a smaller pulley on genny????
Other things may be to check brushes for length,,,,,,insure brush hold down springys are good n tight,,,,,,,,insure commutaTOR IS CLEAN and free or oil or carbon ,,,,,,,,,if third brush adjust,,,,,,,,,INSURE VR well grounded,,,,,,,,belt,,,
Unless youre gonna run hours n hours with all lights on May just live with if the above is all good
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
