When I have been inside the gov's on the A's, I have had to go though the front. Meaning you will need to pull the radiator, but you will be able to leave the distributor in place. The spring is in the gov housing. If you end up pulling the gov weight assembly out, watch the timing marks is all. While you are in there, check the bearing too.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
