No you dont need to remove the dist. Just dont move the gear that drives it. Its not easy but it can be done ive done it many times. Get the new spring from IH for the A or B as they take the same. If theres no response from the throttle thats the problem. Check the bearings on the shaft they are in three parts its called a thrust bearing..
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
