[quote="Indiana Ken"](quoted from post at 10:11:52 01/25/13) Quoting Removed, click Modern View to see
It is basically a solution in search of a problem that you are not likely to ever see. It really only applies if the alternator wire on the #2 terminal is connected remotely such as at the starter solenoid instead of the alternator output terminal. Connected remotely gives better control over the battery voltage than having it connected at the alternator.
Connect them in parallel.
When starting the diode will provide low resistance to energize the alternator. It will also prevent any current from flowing back to the switch which ensures that the switch can control the power to the coil.
The problem with having only a diode in the circuit to energize the alternator is if the wire between the alternator output and the battery should become open all the current would be fed through the #1 terminal back to the switch. With no path back to the sensing wire the alternator voltage will rise until it destroys the alternator. The resistor allows some of the current to flow back through the circuit so the sensing wire can still control the voltage but limit the current to prevent over loading the circuit.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
