Re: Gear oil for M
Posted by Patrick HMD on January 26, 2013 at 14:52:01 from (75.0.239.191):
In Reply to: Gear oil for M posted by Patrick HMD on January 25, 2013 at 13:51:37:
Well, I ended up with over 1 1/2 gal. of gear oil in the drain pan before i screwed the plug back in. And even then it was still seeping out a bit. Didn't realize I was carrying around that much excess baggage. I did loosen the bottom 2 drains and got very little water.
I can understand a quart plus or minus would not make that much difference, but 1 1/2 gals. seems like a lot, and I'm thinking it's due to water displacement. There was some water mixed in with the drained oil. The oil is very, very thick. As it was draining into the pan, it looked like cake batter being poured into a baking pan. That same consistency. Maybe thicker yet. I'm going to run it as is without the extra oil. I hope nothing blows up. lol
Thanks guys.
Patrick
'49M
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
