Posted by rhtx55 on January 29, 2013 at 16:38:26 from (68.185.207.25):
In Reply to: Water in oil pan posted by Matt E. on January 29, 2013 at 11:49:31:
The only way to determine if the block or head are cracked is to strip them down, have it " tanked" to remove the rust & carbon, have them both magnfluxed & pressure tested. You will usually find minor cracks in both, only the machine shop can help you determine if they need to be repaired, or will be fine as is.
If your pockets aren't very deep, I would try new sleeves and pistons, put them in & pressure test the coolant system with the pan, manifold, and valve cover off, place a piece of clean cardboard underneath and see what you have the next morning. If no leaks after 8 -12 hours of being under pressure, you should be good to go.
The water was probably built up condensation from sitting outside those years, they will build up condesation even sitting in an enclosed shed.
Strictly a guess......
How much water was present in the oil pan when you removed it ?
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
