To summarize the other answers, the rotor is way off, supposed to be 2 o-clock pointed to the #1 terminal, at a minimum your carb has a bad gasket, and make sure the float is at the right height, if you have not cleaned the carb with real carb cleaner, do so. All carburators used or made by IH will flood if you try cranking with the choke closed. Begin with it off and only open for a couple of seconds while cranking. Also when you time the engine with #1 at TDC, and have the rotor pointing to #1, remove the coil wire from the distributer and put the end about 1/4 inch from the nut on the distributer (switch on), turn the distributer to the left (from rear) then turn to the right until you get a spark.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
