You have severe carb problems. When you get that fixed you need to remove all plugs. Then removing the valve cover get #1 piston on compression. Both valves will be closed. Looking in the #1 hole you can see the piston at the top. The rotor should be at 2 o"clock when dist is installed. Make sure the wire goes to #1 the next wire goes to #3 the next wire #4 next wire #2 hook the wire to #1 plug not installed. make sure the plug is grounded. By turning on the sw and turning engine over having thumb in #1 hole you can see spark at the plug when you feel compression. This will tell you timing is OK. If the carb is fixed the engine will start and run after all plugs are installed and the wires are in the correct order. You can time the engine by moving dist while its running by sound of the engine. You should never see gas at the gasket on the manifold.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
