Remove No1 sparkplug near the radiator. Hold your thumb over the plug hole while a helper hand cranks the engine. Once you feel pressure against your thumb drop a long plastic straw on top of the piston. Then you watch the straw rise while the helper slowly cranks the engine. Once the straw quit rising your No1 piston should be a TDC on the compression stroke.
Remove the distributor cap and pull the distributor from the engine and rotate the rotor until it points to 2 o'clock and reinstall the distributor.
As been mentioned install the plug wires in this firing order: 2-1 4-3 As the rotor rotates CW.
Make sure you're getting battery voltage to your distributor. It should start now. Hal
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
