Bearing install
Posted by Bkpigs on February 20, 2013 at 19:22:46 from (24.182.229.14):
When installing a bearing on a shaft that is press fit, do you guys use a punch on the inside race to fit it? I used a rubber mallet as a block and hit it with a hammer. I figured the rubber mallet would spread the force over a wider area and lessen the shock. Now the bearing has a slight click that I didn't notice before. Never had this issue before but this bearing was one of the tightest I can remember. Thanks!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
