Posted by pete 23 on February 28, 2013 at 17:39:35 from (74.47.40.242):
In Reply to: 400 diesel missing posted by Brad clemmons on February 28, 2013 at 11:21:35:
The decompression valves are open when on gas. They close when switched to diesel. So, if you pull the spark plugs out, put decompression lever in diesel position,ground coil wire or unhook primary wire to coil so you don't stat a fire, hit the starter and no compression should come out of the spark plug holes. If it does, decompression valves are stuck or warped. You can get get at the top end of them valves with valve cover off. May be able to see a stuck valve through spark plug hole. Difficult though. If they are not stuck too bad you can go through hole and push them up. Then pull lever back to gas to open them, then again to diesel. Doing that several times may loosen them. Probably not though.
Today's Featured Article - Show Coverage: Godfrey, Illinois Country Days - by Cindy Ladage. Except for last fourth of July's Old Gold show in Springfield, Illinois, I don't remember when it was so hot. Nevertheless, the heat didn't keep vendors and visitors alike from enjoying the third annual Country Day's Event. Jane Elliott said the event was originally a one man show. "Barry Seiler, owner of Country Town Farm Supply store used to invite people up to the Johne Deere store. He would give hats and a free meal for everyone that brings a tractor." Elliott said while this
... [Read Article]
Latest Ad:
[More Ads]
