Re: Disconnect Transmission Countershaft Coupling
Posted by farmallboy15 on March 09, 2013 at 18:40:16 from (198.228.228.173):
In Reply to: Disconnect Transmission Countershaft Coupling posted by F4RM@11 on March 09, 2013 at 18:36:25:
If it's the same as an h, which I believe it is, there should be
two cotter pins you remove then slide the collars in and the
coupling comes out.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
