If you are jumping to the connection stud on the starter switch with a jump from an external battery, you are effectively eliminating the installed battery and the connections from it to the starter. Steps: Remove the nut and washers from the switch that hold the battery cable, and the wire to the amp meter. Clean this connection with 120 grit sand paper and reinstall. Try it.
Remove the battery terminals at the battery and clean them, then replace and tighten. Try it.
Check the voltage of the battery. If 6v it should be 6.3 volts or more.
If 12v it should be 12.6v
If less than that (either) it needs to be charged and retested. If still low the battery is probably bad.
Charging voltage is 7 volts to 7.2 volts on 6 volt systems. It is 14.2 to 14.6 volts on 12v systems. Start a new post, this one is getting old and far back in the pages. (I use the classic view) Jim
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
