If its a 12 volt system and has a true 12 volt coil YOU DO NOT USE A BALLAST OR THE SPARK WILL BE VERY WEAK.........(Toss the ballast)
A true 12 volt coil may be labeled "12 volt" orrrrrrrrrrrrr "12 volt NOT for use with ballast resistor" or "12 volt no ballast required"
A coil labeled "6 volts" or "12 volts for use with Ballast resistor" is in reality a 6 volt coil AND DOES NEED A BALLAST ON A 12 VOLT SYSTEM or it will overheat plus burn points quickly
Contrary to Billy Bob and Bubbas belief those coils DO NOTTTT I REPEAT NOTTTTTTTT HAVE A STAND ALONE DISCRETE BALLAST RESISTOR TUCKED AWAY SOMEWHERE INSIDE THE CAN.
Many typical old tractor 12 volt coils will have a LV primary resistance (measured between + and - terminals) of around 2.5 to under 4 ohms
If you have a 12 volt tractor and a 12 volt coil DO NOT USE A BALLAST OR THE SPARKS VERY WEAK
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
