Re: Float Height on a Super A Carter Carb?
Posted by Haas on November 19, 2000 at 16:45:45 from (129.37.117.18):
In Reply to: Float Height on a Super A Carter Carb? posted by Tyler (MD) on November 19, 2000 at 09:28:39:
Well, on my C with Carter Carb, I had trouble with it flooding. Gas would run out the drainage hole in the air line, and the tractor would hardly run. I thought the float was sticking, but apparently it was the float set too high and not shutting off the gas. I did not know where it was supposed to be set, so I guessed. Don't have a measurement, but I set it by bending the tab on the float that pushes up the needle valve so the float only had to move a small amount to close the needle valve. Now the tractor runs great and does not flood or leak any gas, although I still shut the gas off when it's in the shed.
Post A Followup
: Re: Re: Float Height on a Super A Carter Carb?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
