Re: Float Height on a Super A Carter Carb?
Posted by Garnet on November 19, 2000 at 17:59:45 from (142.177.73.25):
In Reply to: Float Height on a Super A Carter Carb? posted by Tyler (MD) on November 19, 2000 at 09:28:39:
Tyler Specs for the Carter Model UT (used on C 123) Super C is 11/64" + or - 1/64" from gasket surface to nearest corner of float or 1 15/64" + or - 1/64" from gasket surface to lowest corner of float. Not sure if this is same for your model Carb.
Post A Followup
: Re: Re: Float Height on a Super A Carter Carb?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
