Re: Horn Mfg Loader Tip
Posted by gene b on November 19, 2000 at 21:28:00 from (63.42.174.6):
In Reply to: Horn Mfg Loader Tip posted by Jeff on November 19, 2000 at 17:44:39:
what is the tractor you are using are you sure your not using the delayed lift on the H or M run both cycls out of the same port put a tee between them no need for any thing else
Post A Followup
: Re: Re: Horn Mfg Loader Tip
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
