Re: Another charging system post
Posted by John T on May 23, 2013 at 19:34:08 from (216.249.76.176):
In Reply to: Another charging system post posted by Dennis K (WA) on May 23, 2013 at 13:51:06:
I"m with the guys as far as its a failed/open Low charge Field Resistor on that LHDB switch. I think thats the flat wound one and the coiled wire one is the light dimmer resistor???
The switch itself must have a good ground if she charges so well on high charge which essentially places the Field at dead (no resistor) ground.
If you unhooked the wire on the light switch that feeds down to FLD on the genny and place an ohm meter there to frame ground, it should read near 0 ohms in High Charge and around 3 or so in Low charge. If in Low charge its an open circuit (not the 3 ohms) she cant charge in that Low position.
John T
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
