Re: WD9 has a knock.
Posted by Owen Aaland on May 26, 2013 at 00:55:26 from (216.47.34.124):
In Reply to: WD9 has a knock. posted by Grabatire on May 24, 2013 at 19:52:41:
Your description of the noise is consistent with having something stuck in the top of a piston and hitting the head. When the engine is cold there is enough clearance so it does not hit. As the aluminum piston expands with heat the foreign material starts to impact on the head.
This type of noise, unlike a loose bearing, is not likely to change much depending upon whether or not the cylinder is firing.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
