9/10 volt drop from battery to resistor could indicate a corroded ignition switch or bad wiring.
The coil appears to be new. Are there markings on it such as "12 volt external resistor required" indicating that it needs the resistor or could it be a true 12 volt coil that needs no resistor? I've also seen 12 volt conversion kits with a resistor with too much resistance. It should be about 1 1/2 ohms
Output of coil to distributor should read near battery voltage with points open, near zero with points closed.
It also appears to me that the wires on top edge of alternator may be reversed. #2 on right should loop down to big output stud. #1 on left should connect to the ignition switch with a diode in the line to prevent engine continuing to run with switch turned off?
One check would be to disconnect wire from + side of coil and run temporary wire direct from battery + and see if you get spark. This will bypass switch, resistor and that section of wiring.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
