Hang in there...willing to learn is the important part. Learning is often impatient and frustrating.
"The coil is 12v w/o resistor so, the way I understand it, it needs to have a resistor ahead of it."
What exactly does it say on the coil? The terminology "12 volt w/o resistor" sounds like it could be saying "12 volt no resistor required"
A coil is actually a transformer with one side of the primary and one side of the secondary tied together. A direct 12 volt coil does not have a resistor inside of it. The difference between a 6 volt and a direct 12 volt coil is in the number and ratio of turns of wire.
Also check resistance to ground from the -- (negative) post on the coil to distributor with the points open. If this shows a low resistance check for shorted feed through on side of distributor, short in points connection or a shorted concenser. Also check resistance from + to -- posts on the coil. Should be either about 1.5 ohms (6 volt) or about 3 ohms (12 volt). Either + or -- to the center post of coil should be several thousand ohms.
Owen is "right on" about the alternator. Disconnect alternator as he instructs and get it running before you worry about the charging system. Keep battery charged with external charger.
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
