Re: Farmall M Transmission Bearings
Posted by riverbend on July 14, 2013 at 17:42:47 from (65.73.80.218):
In Reply to: Farmall M Transmission Bearings posted by Brady Miller on July 14, 2013 at 08:03:22:
I found that when replacing bearings in my H that the original IH bearings have more balls than aftermarket ( or even current CIH ) offerings. Typically the more balls in a bearing the more load it can handle.
If you are not going to work the tractor, almost any bearing will do. If you are counting on it to get something done, the quality of the bearings might be an issue.
Greg
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
