I too, looked at the parts catalog for the 706 and it does indeed show different parts than my 756 catalog. Years ago when I added the second valve to my 856 I got a valve from a salvage yard. It had hydraulic fitting elbows on top at the exit ports instead of the banjo fittings with steel tubes. Apparently someone had used it with regular hydraulic hose instead of the steel tubing to go to the "blocks". Before you go to modifying that dual tube assembly ( known as the manifold) , you may want to consider having hose and fittings made up to use on the left valve and run them to the right "block" and use the dual tube manifold on the right valve and run to the left block .
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction,
... [Read Article]
