Not to hard, under the pump mark how the slot is positioned before removing it if needed to install back the same. Put a screwdriver or something in the drive slot to twist back and forth for the backlash using a dial indicator if you have. The gear and shaft passes through a adapter that is oval shaped to change the backlash. Has different holes you can spin it to. Oil seal is under the adapter. Been so long ago that I can't remember if the shaft has a o ring or seal on it also. Anyway the slotted shaft with gear and adapter will pull out and you can see what's needed. Just don't turn the engine and put the slot back the same direction. Think I remember a dimple or mark on one end of the slot. Not sure of my memory though. Last one I did everything was worn so much it took all the adapter would give to get the backlash to .006 I think it was.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
