Temporary Wiring - 1951 Cub
Posted by anvilheadtexas on August 06, 2013 at 17:22:44 from (99.117.216.44):
Okay - after hooking up 6 volt positive ground battery to teh battery cables AND NOT the jumper cables, my cub cranks fine. The next step is to wire so I can see if I get spark. I am going to by pass the ignition and ampmeter cause I already dismantled the dash. I only want to see if I can get spark and then maybe fire....then I strip down the rest of the way.
Question...if I by pass the dash, I will wire from the starter directly to the regulator BAT. Then the wire coming out of the regulator from I will go directly to the negative terminal on the coil.
I realize that the current will be constant to the coil so I will build in a temp switch somewhere in circuit.
Any advice?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
