Posted by D Slater on August 19, 2013 at 17:19:39 from (184.14.161.237):
In Reply to: engine bearings posted by truckerlary on August 19, 2013 at 16:55:56:
Think you nailed it. bearings are the same on the OD .050 difference on the ID for small diameter rod journals compared to big diameter cranks. Only difference besides the cranks is thinner or thicker bearings. Don't hold me to it but if I remember correct the mains are .060 bigger on the late crank. 49 came with a small journal, in case it was changed a crank casting number ending in DC or lower is a original small journal.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
