The power beyond end plate should be available from your CaseIH dealer.
With an 806, you may be lucky and have a valve stack with a separate end plate. That way you won't need to also buy another "middle" valve body to use with the power beyond end plate.
398316R1 is the number listed in the online parts book for the power beyond cover, but it's been superseded.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
