240 battery drain
Posted by Fudd on October 22, 2013 at 18:52:23 from (63.228.76.70):
I"m working on a friends 240 that drains the
battery. Today I 1)Disconnected the coil,
2)disconnected the wires from the small post on
the starter relay and the link between the relay
and the starter, 3)Disconnected the generator
wires. The voltage regulator and generator look
fairly new and after removing the VR cover I could
see the points were both open. I think I will
disconnect the voltage regulator just to make sure
that isn"t it. The battery shows 6 volts and with
the positive cable removed I get 3 volts between
it and the battery post. Is this a positive or
negative ground system? When I hook the cable to
the battery, the ammeter does not move. Right now
it is neg. ground. If I remove the neg. cable
from the frame, the drain goes away. Next step is
pull up the instrument panel and check the wires
under there. What hydraulic oil does this take,
it"s low. Wiring diagram? TIA
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
