I have never been a big fan of letting an engine run idle for a long period of time to warm up. Much rather run a few minutes and then under moderate speed and light load gradually increase speed and load to warm engine. BUT, that being said, with all the hydraulics on that tractor you need to let it run for a quite a while to get hydraulic fluids warmed up some. On these pfc hydraulic and closed center valve hydraulics, no oil is going through much of anyplace when not being used so some hook a hose from one aux valve coupler set and circulate the oil though during warm up. The lube system oil will be running quite a lot of oil through system but all the transmission clutch's are dead headed so no circulation through them. Forty gals of cold oil takes quite a while to warm up.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
