Brushes dont make any difference the third is adjustable for out-put. But yours will have three and can be adjusted by loosening the screw on the brush end and rotating that brush for Amperage out-put. If you are running the mag only need a couple amps and the hi-charge position on the sw will increase the amps more. If you are using a dist you will want about 3-4 amps as the mag doesent need any batt supply.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
