Re: tube or tubeless
Posted by old on November 17, 2013 at 18:14:00 from (209.86.226.58):
In Reply to: tube or tubeless posted by RustyR on November 17, 2013 at 17:30:51:
When new that tractor would have used tube type rims and if the rims are made to fit they need tubes since a tube type rim is not the same as a tubeless rim and a tube type rim will not hold air
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
